Having trouble with my RF24
I need help with my RF24.
I followed the Robin2's simple rf24 tutorial and one Arduino prints the "DATA RACIVED" rapidly.
I then tried to use the code which shows the communication between the Arduino and the rf24. and this is what I'm getting and to me this seem that their not communicating properly. Can anyone that me what this really means?
CheckConnection Starting
FIRST WITH THE DEFAULT ADDRESSES after power on
Note that RF24 does NOT reset when Arduino resets - only when power is removed
If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
communicating with the nRF24
SPI Speedz = 10 Mhz
STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1 = 0x0000000000 0x0000000000
RX_ADDR_P2-5 = 0x00 0x00 0x00 0x00
TX_ADDR = 0x0000000000
RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x00
EN_RXADDR = 0x00
RF_CH = 0x00
RF_SETUP = 0x00
CONFIG = 0x00
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1 MBPS
Model = nRF24L01+
CRC Length = Disabled
PA Power = PA_MIN
ARC = 0
AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
and 250KBPS data rate
SPI Speedz = 10 Mhz
EN_AA = 0x00
EN_RXADDR = 0x00
RF_CH = 0x00
RF_SETUP = 0x00
CONFIG = 0x00
Data Rate = 1 MBPS
Model = nRF24L01+
PA Power = PA_MIN
ARC = 0
@bradley_waldner_mg, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
Please post your code here (using code tags) instead of making us search for it :wink:
The Arduino is not communicating, cannot read and write, with the RF24 perhaps ?
You have them wired wrong, the modules are faulty, the Arduino is faulty etc.
