having trouble with my servos.
Hey, I am making this project of a robotic arm for my desk, on my first test this happened, https://streamable.com/0hn6s The servo thrash around like mad, no matter what I do they still do that, and the last potentiometer only is ment to control the last joint yet it kinda moves all of them, Help.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
int potpin1 = A1;
int potpin2 = A2;
int potpin3 = A3;
int val1;
int val2;
int val3;
TIMSK0=0;
myservo1.attach(3);
myservo2.attach(5);
myservo3.attach(6);
myservo1.write(90);
myservo2.write(90);
myservo3.write(90);
delayMicroseconds(100);
TIMSK0=0;
val1 = analogRead(potpin1);
val1 = map(val1, 0, 1023, 0, 180);
myservo1.write(val1);
delayMicroseconds(15);
val2 = analogRead(potpin2);
val2 = map(val2, 0, 1023, 0, 180);
myservo2.write(val2);
val3 = analogRead(potpin3);
val3 = map(val3, 0, 102, 0, 180);
myservo3.write(val3);
Why are you messing with the interrupt masking (TIMSK0=0)? Take those lines out and see what it does.
And what are those delayMicroseconds() for? Servos are mechanical devices and work on millisecond timescales at best. Sending a command than waiting 15 microseconds isn't going to do much.
Steve
Ok I just tried that, it did not help.
btw here is a schematic Tinkercad | From mind to design in minutes
@LMminemagician
The "Report to Moderator is NOT a REPLY button.
Strongly suggest you READ THIS
Bob.
