Having Trouble with NRF24L01
Firstly, I would like to say this is my first time trying to work with Arduino on my own.
Nonetheless, I'm currently trying to work on creating a remote controlled car based on the following video: Video.
While I am able to get my motors properly working and the joystick control, my main issue is that the receiver and transmitters, which are NRF24L01's aren't able to communicate properly. I believe I have my connections correct (for the record they are soldered) and that they mimic exactly what the video shows. Here are my sketches for the receiver and transmitter below:
/*Arduino JOYSTICK CONTROLLED CAR (TRANSMITTER)*/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(8,9); // CE, CSN
const byte address[6] = "12345";
char xyData[32] = "";
String xAxis, yAxis;
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  xAxis = analogRead(A1); // Read Joysticks X-axis
  Serial.print("\n" + xAxis);
  yAxis = analogRead(A0); // Read Joysticks Y-axis
  Serial.print("\n" + yAxis);
  // X value
  xAxis.toCharArray(xyData, 5); // Put the String (X Value) into a character array
  radio.write(&xyData, sizeof(xyData)); // Send the array data (X value) to the other NRF24L01 modile
  // Y value
  yAxis.toCharArray(xyData, 5);
  delay(20);
/*ARDUINO JOYSTICK CONTROLLED CAR (RECEIVER)*/
#include <SPI.h>
#include <RF24.h>
#define enA 2
#define in1 3
#define in2 4
#define enB 7
#define in3 5
#define in4 6
RF24 radio(8, 9); // CE, CSN
char receivedData[32] = "";
int  xAxis, yAxis;
int motorSpeedA = 0;
int motorSpeedB = 0;
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  if (radio.available()) {   // If the NRF240L01 module received data
    Serial.print("RECIEVED");
    radio.read(&receivedData, sizeof(receivedData)); // Read the data and put it into character array
    xAxis = atoi(&receivedData[0]); // Convert the data from the character array (received X value) into integer
    delay(10);
    yAxis = atoi(&receivedData[0]);
    Serial.print(xAxis + "\n");
    Serial.print(yAxis + "\n");
    delay(10);
  // Y-axis used for forward and backward control
  if (yAxis < 470) {
    // Set Motor A backward
    digitalWrite(in1, HIGH);
    digitalWrite(in2, LOW);
    // Set Motor B backward
    digitalWrite(in3, HIGH);
    digitalWrite(in4, LOW);
    // Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
    motorSpeedA = map(yAxis, 470, 0, 0, 255);
    motorSpeedB = map(yAxis, 470, 0, 0, 255);
  else if (yAxis > 550) {
    // Set Motor A forward
    digitalWrite(in1, LOW);
    digitalWrite(in2, HIGH);
    // Set Motor B forward
    digitalWrite(in3, LOW);
    digitalWrite(in4, HIGH);
    // Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
    motorSpeedA = map(yAxis, 550, 1023, 0, 255);
    motorSpeedB = map(yAxis, 550, 1023, 0, 255);
  // If joystick stays in middle the motors are not moving
  else {
    motorSpeedA = 0;
    motorSpeedB = 0;
  // X-axis used for left and right control
  if (xAxis < 470) {
    // Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
    int xMapped = map(xAxis, 470, 0, 0, 255);
    // Move to left - decrease left motor speed, increase right motor speed
    motorSpeedA = motorSpeedA + xMapped;
    motorSpeedB = motorSpeedB - xMapped;
    // Confine the range from 0 to 255
    if (motorSpeedA < 0) {
      motorSpeedA = 0;
    if (motorSpeedB > 255) {
      motorSpeedB = 255;
  if (xAxis > 550) {
    // Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
    int xMapped = map(xAxis, 550, 1023, 0, 255);
    // Move right - decrease right motor speed, increase left motor speed
    motorSpeedA = motorSpeedA - xMapped;
    motorSpeedB = motorSpeedB + xMapped;
    if (motorSpeedA > 255) {
      motorSpeedA = 255;
    if (motorSpeedB < 0) {
      motorSpeedB = 0;
  // Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
  if (motorSpeedA < 70) {
    motorSpeedA = 0;
  if (motorSpeedB < 70) {
    motorSpeedB = 0;
  analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
  analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
  Serial.print("\n");
  Serial.print(motorSpeedA);
  Serial.print("\n");
  Serial.print(motorSpeedB);
For the outputs on the serial monitor, I am getting the correct values for the transmitter, but the receiver is stuck at 0 for one axis and 510 for the other axis. While I do believe this is definitely an issue with the transmission of data, I would appreciate any help to try to get the data to work properly. Thank you for your help and any questions please ask!
Edit: For the record I am using an Arduino Nano for both the transmitter and receiver.
Thinking helpers will watch videos is asking for too much. Filter out the essential facts and tell us.
Using Serial.print and serial monitor, verify that the intended data is sent,
Then do the same on the receiving side.
Schematics might be useful.
Many times similar problems to yours are caused by hardware power source etc. Post an annotated schematic showing exactly how it is wired, be sure to show all power sources, ground and power connections.
Sorry for the later reply, I have everything working now, I accidentally soldered two pieces together that shouldn't have been soldered. Thank you for your help.
