http://m.instructables.com/id/LASER-Maze-Halloween-Haunted-House/
I think the code is out dated it throws an error when I try to publish any help is appreciated
Tadkins50:
What error? Nobody can advise if you don't quote the exact error. I downloaded the Arduino code from the Instructable and it compiles for me. (Edit... Uno R3 and IDE 105)
Post the code , tell us which IDE you are using an the error!.
Mark
#include <Servo.h>
// servo will be used to flip a switch on the red beacon light
Servo myservo;
// constants to set up pins
int mySensors = {A0, A1, A2, A3, A4, A5}; // analog pins with CDS cells to detect laser beam
const int numSensors = 4; // total number of CDS cells used ###MODIFY IF NEEDED###
// variables to handle analog values from CDS cells
int curValue; // stores the value of the CDS cell that is currently being read
int prevValue[numSensors]; // stores the previous value of each CDS cell
int baseValue[numSensors]; // stores a baseline value for each CDS cell when the laser beam is not broken
int shouldAlarm[numSensors];// flag to decide if alarm signal should be sent
int sensitivity = 35; // an offset from the baseValue to determine if laser beam is broken ###MODIFY IF NEEDED###
int sendAlarm = 0; // determines if we should send the alarm signal to the COM port
// variables to control red beacon light
int alarmLength = 3000; // how long red light should remain on in milliseconds - synch with mp3 played by processing ###MODIFY IF NEEDED###
unsigned long alarmTime;// time alarm was activated
int onPos = 50; // on position for servo ###MODIFY IF NEEDED###
int offPos = 110; // off position for servo ###MODIFY IF NEEDED###
// initialize the serial communication to PC
// Serial messages sent to processing. The digit in the ones place tells us what kind of data we have.
// ####0 - data from A0, where #### is the data and 0 is the code telling where the data belongs
// ####1 - data from A1
// ####2 - data from A2
// ####3 - data from A3
// ####4 - alarm trigger value for A0, where #### is the value and 4 is the code telling where the data belongs
// ####5 - alarm trigger value for A1
// ####6 - alarm trigger value for A2
// ####7 - alarm trigger value for A3
// 8 - alarm servo on
// 9 - alarm servo off
// attach the servo to pin 9
myservo.attach(9);
myservo.write(offPos);
// set all of the CDS cell analog pins as inputs
for (int thisSensor = 0; thisSensor < numSensors; thisSensor++) {
pinMode(mySensors[thisSensor], INPUT);
calibrate();
// check each CDS cell to see if the laser beam is broken
curValue = analogRead(mySensors[thisSensor]);
Serial.println(curValue*10+thisSensor);
// A broken beam is detected if the current sensor value and
// the previous value are both less than the base value
// minus the sensitivity.
if (curValue < (baseValue[thisSensor] - sensitivity) && prevValue[thisSensor] < (baseValue[thisSensor] - sensitivity) && shouldAlarm[thisSensor] == 1) {
// laser beam has been broken, alarm should be sent
Serial.println(“8”);
shouldAlarm[thisSensor] = 0;
// activate servo to turn on red beacon light
myservo.write(onPos);
delay(20);
alarmTime = millis();
// laser beam not currently broken, so reset the alarm flag
else if (curValue > (baseValue[thisSensor] - sensitivity) && prevValue[thisSensor] > (baseValue[thisSensor] - sensitivity)) {
shouldAlarm[thisSensor] = 1;
prevValue[thisSensor] = curValue; // update the previous value
// deactivate the servo if it has been more than alarmLength
if (millis() - alarmTime > alarmLength) {
Serial.println(“9”);
delay(20);
void calibrate() {
Serial.println(“CALIBRATING!”);
// for each CDS cell, average three readings together to
// calculate base value when laser beam is not broken
baseValue[thisSensor] = analogRead(mySensors[thisSensor]); // first reading
delay(20);
baseValue[thisSensor] += analogRead(mySensors[thisSensor]); // plus second reading
delay(20);
baseValue[thisSensor] += analogRead(mySensors[thisSensor]); // plus third reading
baseValue[thisSensor] /= 3; // divided by 3 to find average
Serial.println((baseValue[thisSensor]-sensitivity)*10+4+thisSensor); // last digit tells processing this is an alarm trigger value
it says serial port com8 not found Duemilanove board
The IDE on your PC is not seeing your arduino. Try selecting the correct comm port.
(Read the getting started instructions)
Mark
How did you make the leap from here:
.... to here:
