Having trouble with the equality operator: '=='
Hi Folks,
Stuck again.
I have a variable named TI that has the value 13, that refuses being compared.
int TI;
Serial.print("’");
Serial.print(TI);
Serial.println("’");
// Complete message. (13 tokens.)
if (TI != 13) {
Serial.println(“Huh?”);
Serial.println((TI == 13));
return false;
The code returns.
‘13’
Huh?
0
(13 == 13) evaluates as true, but not (TI == 13) evaluates as false.
Any ideas?
Please post a complete program that illustrates the problem
The code you posted says "if (TI != 13)". That's not equal. Then you print (TI == 13), the result of comparing it to 13. So it prints 0 which equals false. Which you should already know because if it is 13 it skips the print.
Steve
UKHeliBob: This IS the relevant part that doesn't work!
slipstick: Nice try, but you miss the issue.
Serial.print prints 13. That is TI = 13.
The if statement treats TI != 13 as true, which is not the case. The if code block should never be entered.
TI == 13 should be true, but it's false.
TI seems to be the issue but I can't see why.
The purpose of the if is to exit the routine if TI is not 13, TI must be 13 to continue.
But it is not a complete program that would allow us to try it for ourselves
What type variable is TI?
UKHeliBob:
@OzMaz, when you finally post a complete program, do so using Code Tags as described in Item #6 here: Read this before posting a programming question .... Despite the rather obvious title, you appear to have missed that post.
The problem must indeed be elsewhere. When I try a program using the snippet you posted, I get the correct result:
  int TI = 13;
  while (!Serial);
  Serial.print("**");
  Serial.print(TI);
  Serial.println("**");
  if (TI != 13) {
    Serial.println("Huh?");
Displays only:
13
So the if condition provides correct result and no ‘Huh?’
Big apology folks, I got it wrong.
I wrote more items than was assigned to the Buffer and boom, buffer overrun, crazy results.
Well, at least you came clean...
