Having trouble with the "if" function
im using a servo motor to release a parachute at a certain altitude however using the if function doesnt seem to work, i have it set to release at a certain temperature as this allows me to test it easier however it doesnt seem to want to do it, this is the code i am using
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ReadAnalogVoltage
#include <Servo.h>
Servo servo;
int sensorValue; //integer variable for value from thermistor
float voltage; //float variable for equivalent voltage from thermistor
float temperature; //float vairable for celcius temperature
int pressureValue;
float pressure;
float pressurework;
bool printFlag = true;
servo.attach(8);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
float temperature = voltage*(-28.084) + 97.767;
// print out the value you read:
Serial.print(voltage);
Serial.print(" v ");
Serial.print(temperature);
Serial.print(" C ");
delay(700);
pressureValue = analogRead (A1);
pressurework = ((pressureValue / 1024.0) + 0.095) / 0.0009;
pressure = (pressurework)-((pressurework)*0.0036);
Serial.print("CanSat_Cupertino");
Serial.print("Pressure = ");
Serial.print(pressure);
Serial.println (" millibars");
if (temperature >= 28 )
servo.write(90);
printFlag = true;
if (printFlag == true)
Serial.print ("Prachute Deployed");
printFlag = false;
delay (500);
the servo code is towards the bottom of the code,
any help is appreciated
Read the forum guidelines. Post your test code in code tags. Use the IDE autoformat tool (ctrl-t or Tools, Auto Format) to indent the code for readability before posting code.
You read an analogue input then do various bits of maths to the result. Break the maths down into small steps and print the result of each step. I think you will find the results are not what you expect.
[quote="morgan_reid03, post:1, topic:874229"]
servo.write(90);
//printFlag = true;  //      <————<<<<
printFlag = false;
[/quote
Thats what i have in but the problem is that the servo turns as soon as the cirvuit is turned out, even when the temperature is less that 28
Add the Serial.prints below.
Serial.print ("Temperature = ");
Serial.println(temperature ); // tell us what gets printed  <———<<<<<
servo.write(90);
printFlag = false;
The default servo position is 90 degrees when the attach() function is executed unless you command it to do something different. Use the write() function with your desired home position before you do the attach()
the value printed is 25.54 for the temperature
What is the problem with that ?
it was still turning to 90 degrees but your previous explanation solved it, it now works as intended thank you very much :slight_smile:
