I have tried everything to get my HC-05 into AT Mode, I have looked up every way from using RX and TX pins to Digital Pins, nothing is working.
I have tried blank sketch to even get into AT Mode (Holding the button) and even tried adding HIGH to Pin 9 nothing is working
//RoboIndia Code for HC-05 with AT Mode
//https://www.roboindia.com/tutorials
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(5, 6); // RX | TX
Serial.println("Enter AT commands:");
BTSerial.begin(38400); // HC-05 default speed in AT command more
if (BTSerial.available()) // read from HC-05 and send to Arduino Serial Monitor
Serial.write(BTSerial.read());
if (Serial.available()) // Keep reading from Arduino Serial Monitor and send to HC-05
BTSerial.write(Serial.read());
there is one of the codes I have used, everything either turns up blank in Serial Monitor OR a bunch of backwards question marks, x’s and strange Boxes.
I have switched to 38400 and using both NL and CR.
Please help, not sure where to go as I have tried everything I could find as far as trouble shooting
I have 3 pieces of HC-05. Old one (borrowed from my friend) works well and also responses to AT Commands.
The other two (Chinese clones) are anew; they work well with Bluetooth Master Terminal; but, they do not respond to AT commands.
The old one enters into AT Mode this way: press and hold the micro switch for about 2-sec; it enters into AT Mode.
For the anew two: power down; hold the micro switch; power up; release the micro switch after 2-sec. The HC-05 appears to have entered into AT Mode; but, it does not respond to AT Command.
All HC-05s work the same way but the breakout boards on which they sit can vary and quite a few tutorials don’t reflect this. Two things can happen to spoil things.
You are using a tutorial for a JY-MCU board but have a board with a switch
