HC-05 AT Commands Not Returning OK
Hello,
I'm trying to set up an adruino uno and hc-05 to be able to upload sketches via bluetooth. I've been using
http://www.joshuanewell.com/electronics/arduino-programming-via-bluetooth
as a plan, however when I reach the point where I provide AT commands instead of returning OK I receive ˇs until a new AT command is input then the ˇs restart.
Example(copy pasted)
AT ¯ˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇ
I would love any help that could be provided.
It might be a wiring problem. I don't think that guy knows what he is doing, and you might get a better deal here.
http://www.martyncurrey.com/arduino-with-hc-05-bluetooth-module-at-mode/
So I have those steps and come up with
BT STATE = ´´™†™'ï™FU b•µäàçÜœßÜÖ
I do have the serial monitor set to both NL & CR and 9600 baud.
would the problem be something like this post?
http://forum.arduino.cc/index.php?topic=128907.0
I'm using IDE 1.6.0 and OSX 10.6.8.
Any ideas?
I got the AT commands to work but now when i get it set up to upload a sketch via bluetooth I get the error
programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
up to attempt 10.
The garbage you got was probably because you were not working at the AT mode default speed 38400. I can't comment about uploading via bluetooth, but it is just possibly the same problem.
