HC 05 ble module not connecting
Hi!
I have two HC 05 modules(ZS - 040 with button).
The problem is, that I'm unable to establish any kind of connection.
First I tried to connect it using software serial ports, but I got nothing. Then I tried hardware serial and got the same results. I tried simple example sketches I found on the Internet. I couldn't connect to it.
Serial.available() returned false
Even if i just connect it to pover and ground, I'm unable to see them on my phone(and any other phone).
Also the LED is blinking fast. I can also start it in AT mode when I hold the button on start, because the LED then blinks slower, but either way, I couldn't get connection.
I would be very grateful for any help.
HC-05 is not a BLE device.
There is no "either way" If the LED is flashing fast, you will never get a connection. If it is slow, the phone should be able to sniff for it. This is a phone procedure done in phone settings. This presupposes the phone is Android and your Bluetooth really is an HC-05.
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
Thank you very much for the answer. I'll look into it and will try baud rate 9600. I don't think I've tried that
In the document, I keep reading, that it should be ready "out of the box".
If i connetct it to D0 and D1 pins. Should this code work in a sense, that if the module could communicate with PC, it will write to the Seerial monitor Available?
if (Serial.available())
Serial.println("Available");
Serial.println("Not Available");
Because I get non available message only.
I am moroon for not reading the Serial library. Consider this closed and I'm sorry for wasting your time
