Hi fellow Arduinians, I've been working on a small project here and ran into a bit of a wall
Hopefully someone who has experience with serial communications, bluetooth comms, Arduino uno, and 16x2 LCDs can help me with my dilemma.
So, here's what's happening:
I am trying to get a string of data programmed to an Arduino UNO, which will then transmit the data to an HC-05 bluetooth module set in master mode, which will then broadcast that data to another HC-05 bluetooth module set in slave mode. The slave module needs to send the data back to the Arduino so it can be programmed to finally print the data to a 16x2 LCD.
To add more, the master module will need to be activated using a photoresistor (LDR). Once activated, the string of data ("message") that is being sent to the master bluetooth module to be broadcast will be changed to a different "message." I'll worry about the photoresistor part later.
So far, I have this much accomplished:
- Bluetooth modules are both configured, one set as master and one set as slave.
- A small bit of Arduino programming to let me know both modules are communicating with each other.
Here's the code I have for bluetooth module comm testing:
Serial.println("Message 2017");
I am getting communications between the two bluetooth modules I just need to verify that the message I have in my program ("Message 2017") is what is being communicated, so I thought the best way to do that would be display it on an LCD.
MY QUESTION IS THIS:
Can anyone explain how to wire the LCD and slave bluetooth module so that the message received by the slave module will show up on the LCD? Being that I am new to Arduino's libraries and methods and/or functions, I will probably need some programming advice if I need to do more programming to make it work.
Thanks for any help!!
