When my HC-05 is not connected to a device, it blinks 5 times a second as it should. However when it is connected, from all the videos I see of it working properly online, It should blink two times fast every few seconds.
When I connect my HC-O5, it blinks twice at a much slower rate. This causes a specific problem.
The specific problem is that when my HC-O5 is blinking twice, any 'a' or 'd' I send via a Bluetooth terminal is delayed until the HC-05 finishes blinking twice. When the HC-05 finishes blinking, the commands I send in the Bluetooth terminal are executed instantly. However the instant the HC-05 blinks twice again, every command waits until it finishes the blinking twice before executing.
Here is the code, the Arduino is being powered by a 9v battery. It is being run through a bluetooth tereminal on an android phone.
pinMode(7, OUTPUT); // put your setup code here, to run once:
if(Serial.available()>0)
char data= Serial.read(); // reading the data received from the bluetooth module
switch(data)
case 'a': digitalWrite(7, HIGH);break; // when a is pressed on the app on your smart phone
case 'd': digitalWrite(7, LOW);break; // when d is pressed on the app on your smart phone
default : break;
Serial.println(data);
delay(50);
