if(Serial.available() > 0){
state = Serial.read();
flag=0;
if (state == '0') {
digitalWrite(ledPin, LOW);
if(flag == 0){
Serial.println("LED: off");
flag = 1;
else if (state == '1') {
digitalWrite(ledPin, HIGH);
if(flag == 0){
Serial.println("LED: on");
flag = 1;
I connect with my xperia l by ArduDroid app, I can connect and get data from arduino but I can't send any data, when I open serial monitor at Arduino Ide and send 1 or 0 led is on or off but by android app i can't ;/
I don't know why that is.
Please help me
kse1:
Hi
I have bluetooth module HC-05 and I C=connect with my Uno
I guess you already know that there is nothing wrong with the code, and the wiring sounds fine. I don't know what an xperia is, or anything about ArduDroid, but it sounds like you are using an Android devicee, and are going through the right procedure. If the LED on the Bluetooth is solid, you are connected, and Android should tell you that anyway.
Your code works fine when using Bluetooth Terminal on my Android phone. I suggest you try that.
I download Bluetooth Terminal on my Android device, I can't send 1 or 0.
When I send 1 at Serial Monitor led is on and at Bluetooth Terminal I get "LED: on"
I think my RX pin at Arduino is damaged ;/
Led on hc-05 is blink but when I connect with my Android device is blink twice and off for 2 seconds.
kse1:
You could be right
I'm afraid I don't understand this
Can I make RX and TX at another pin ?
Yes you could try using software serial. This allows you to pins other than D0,D1 and this is the only time when it makes sense to do so. There are several examples around. You will need the software serial library
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
I write something at SerialMonitor and get this at Bluetooth Terminal on Android device and write on Android and get at SerialMonitor.
But when I make code like this
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
int stan;
int led = 13;
So.....
You have two programmes there, both using software serial. Are you saying the first runs OK and the second does not?
It seems that the only difference is the LED control and it might be time to suspect the LED. You can test this with a blink programme. I don't know anything about LEDs or software serial, but your original programme works OK. If the first programme with software serial works OK, at least you have proved the bluetooth module is OK.
hi, if u having trouble in making into AT mode of HC-05 (ZS-040)(especiall if one having en/wakeup up pin instead of key pin) and trouble in transfering data between two hc05 module . Follow they bellow procedure
Power off HC-05 module.
Press and hold small button above EN pin.
Power on and keep pressing small button.
Small LED should start to blink slowly about once every 2 seconds.
for more info visit below site:
another good reference for making it into master mode is here:
I am working on a project on TPMS. since I am not using android or computer. I need suggestion on using just bluetooth modules to transmit data and receive them using another bluetooth module.
kse1:
Hi
Tx->Rx
Rx->Tx
5v->5v
GND->GND
I have code from youtube
Please help me
