Hello! I've been building an RC BB-8 using ASCAS's tutorial on Instructables and it was going pretty well until yesterday. I was tweaking things with my code when all of a sudden my HC-05 bluetooth module wouldn't turn on for about a minute or so. After that, it would turn back on and allow me to connect with my android device and the LEDs would blink in their usual patterns, but now I couldn't control the motors from it. I first checked to see if there was something wrong with my Arduino or Motor Driver by uploading code that would make the motors work at a constant speed and that turned out just fine, so I know something with my bluetooth module is causing the problem. After doing some research, I didn't really see anyone with a definite solution to my problem so I decided to make my own post. This is my first time really diving into a project like this so I've had some difficulty troubleshooting, but I wonder if I may have accidentally burned something out on the module by keeping it in its plastic case while running. I am probably going to order a new module, but I really want to figure out what happened to make sure I don't make the same mistake again. Thank you!
My Bluetooth Module: Amazon.com
Code:
#include <DualVNH5019MotorShield.h>
DualVNH5019MotorShield md;
#include <Servo.h>
Servo myservo;
char dataIn='S';
char determinant;
char det;
int vel = 200; //Bluetooth Stuff
int overdrive = 13; //Press Toggle Switch #1, the pin13 LED will light up
void setup(){
Serial.begin(9600);md.init();
myservo.attach(6);delay(100);
myservo.write(90);delay(100);
void loop(){ det = check(); // You'll need to reconstruct this if your not using the Pololu Dual VNH5019
while (det == 'F') // F, move forward
{md.setSpeeds(vel,vel);det = check();}
while (det == 'B') // B, move back
{md.setSpeeds(-vel,-vel);det = check();}
while (det == 'L') // L, move wheels left
{md.setSpeeds(-vel,vel);det = check();}
while (det == 'R') // R, move wheels right
{md.setSpeeds(vel,-vel);det = check();}
while (det == 'I') // I, turn right forward
{md.setSpeeds(vel,vel/2);det = check();}
while (det == 'J') // J, turn right back
{md.setSpeeds(-vel,-vel/2);det = check();}
while (det == 'G') // G, turn left forward
{md.setSpeeds(vel/2,vel);det = check();}
while (det == 'H') // H, turn left back
{md.setSpeeds(-vel/2,-vel);det = check();}
while (det == 'S') // S, stop
{md.setSpeeds(0,0);det = check();}
//---------------------Toggle switch code------------------//
/*while (det == 'W'){myservo.write(180);delay(100);det = check();}
while (det == 'w'){myservo.write(90);delay(100);det = check();}
while (det == 'U'){myservo.write(0);delay(100);det = check();}
while (det == 'u'){myservo.write(90);delay(100);det = check();}
int check(){
if (Serial.available() > 0) {dataIn = Serial.read();
if (dataIn == 'F'){determinant = 'F';}
else if (dataIn == 'B'){determinant = 'B';}else if (dataIn == 'L'){determinant = 'L';}
else if (dataIn == 'R'){determinant = 'R';}else if (dataIn == 'I'){determinant = 'I';}
else if (dataIn == 'J'){determinant = 'J';}else if (dataIn == 'G'){determinant = 'G';}
else if (dataIn == 'H'){determinant = 'H';}else if (dataIn == 'S'){determinant = 'S';}
else if (dataIn == '0'){vel = 400;}else if (dataIn == '1'){vel = 380;}
else if (dataIn == '2'){vel = 340;}else if (dataIn == '3'){vel = 320;}
else if (dataIn == '4'){vel = 280;}else if (dataIn == '5'){vel = 240;}
else if (dataIn == '6'){vel = 200;}else if (dataIn == '7'){vel = 160;}
else if (dataIn == '8'){vel = 120;}else if (dataIn == '9'){vel = 80;}
else if (dataIn == 'q'){vel = 40;}
else if (dataIn == 'U'){determinant = 'U';}else if (dataIn == 'u'){determinant = 'u';}
else if (dataIn == 'W'){determinant = 'W';}else if (dataIn == 'w'){determinant = 'w';}
}return determinant;
Tutorial I am Using: https://www.instructables.com/id/DIY-Life-Size-Phone-Controlled-BB8-Droid/
