HC-05 Bluetooth Module Serial Monitor Problem
cyrussantiagoU5c:
Based on the documentations of the device(GizDuino), RX is for 0 and 1 is for TX.
This is the same as any other Arduino, and the connections are as I said in points 1 and 3.
On my intentions, I'm trying to connect a HC-05 Master to a HC-06 Slave. But I cant do that since I can't find another way to pair the two without using the instructions above. module.
Can you recommend another way? I'm trying to digest and apply based on doc(pdf link) you gave me.
OK, the pictures you posted look like they come from the Martyn Currey site. If you want to connect HC-05 to HC-06, that is a pretty good place to get the story but learning to walk before you run might be a good idea, hence the notes I provided, but they only have passing reference to configuration..
Update: I tried to run the .ino file. The only time the serial monitor it giving results is when I setted the line endings to "No line ending" but only giving the last inputted character.
If you are referring to the .ino I supplied, that is not for use with the serial monitor. It is for use with Arduino talking to a phone, or a PC or laptop with a proper terminal programme like RealTerm. If that PC is the one that has the serial monitor on it, disconnect the USB cable as clearly instructed.
