HC-05 Bluetooth Module with arduino
Hello guys,
I'm new here and I'm facing some problems while try to communicate with pre-designed hardware with my hc05+arduino uno.
Problems I faced is as described bellow.
1)How can i connect my hc05 automatically with pre-designed device? I've address of bluetooth used in device. Is it necessary for me to change mode of my hc05 to master?
2)How I come to know that my device is exactly connected with the device I want to connect? Any feedback signal or any function to check it?
3)I want to send command to my device via hc05(i.e. If i send command like read mobile number then device must be respond with mobile number only) How can I read command which are sent to device via hc05?
Thanks in Advance..
What is the pre-designated (?) device.
What software is running on the device to receive and respond to commands from your Arduino?
Can you post a list of the commands it can respond to?
...R
There is TGAM chip and Bluetooth in pre designed device. Which read brainwave data like attention and meditation.
Suppose if i send command like brain.readAttention() then it will send value of an attention. I'm using brain library for simplicity purpose.
You must know if the pre-designed device use classic Bluetooth or Bluetooth Low Energy (BLE). The HC-05 does not support BLE.
Classic Bluetooth module is used in pre-designed device
amv:
Help people to help you. Post a link to the datasheet or user manual for this mystery device.
...R
