HC-05 Configuration Problem
Hi guys, I recently purchased a master-slave module HC-05 for the bluetooth connection.
Initially I used the device without any special configuration except for Ubuntu, but from a couple of days ago I can't make the blink led.
I found several tutorials on Internet for blinking of LED 13. I used Android with blueterm application and python using socket and It worked very fine. After a few days the led blink 13 doesn't work anymore, I associated the module to my android device in fact the LED module change its blink, but when I pressed 1 ( command to turn LED on ) it didn't give me any sign of response..
I also tried to access to the AT mode to change the values ??but I couldn't. I have used windows and ubuntu but the result was the same. With the windows, ide is very slow in fact when I try to enter to the AT command it freezes everything, same thing with ubuntu that when I try to change the baudrate the program crashes!
I also tried to set the COMMAND MODE as suggested by the manufacturer but still the same error xD
Does anyone have any advice? Thanks a lot XD
Sorry for my bad English!
Manifacture Site
http://forum.hobbycomponents.com/viewtopic.php?f=39&t=1567
