I try to know if there is a communication with my arduino HC05 and my computer (Windows 10)
I have done this tutorial : http://www.instructables.com/id/Arduino-Reading-Sensor-Data-Using-Bluetooth/
with my own code :
- CONNECT TO OUTGOING PORT HC-05 'DEV-B' TO VIEW DATA ON SERIAL MONITOR
- USE THIS SKETCH ONLY FOR VIEWING SENSOR DATA ON SERIAL MONITOR.....NOT FOR FILE WRITING
//int temp; //variable to hold temperature sensor value
long tm,t,d; //variables to record time in seconds
Serial.print("hello");
//pinMode(0,INPUT);//temperature sensor connected to analog 0
analogReference(DEFAULT);
//temp = analogRead(0); //analog reading temperature sensor values
//required for converting time to seconds
tm = millis();
t = tm/1000;
d = tm%1000;
Serial.flush();
//printing time in seconds
Serial.print("time : ");
Serial.print(t);
Serial.print(".");
Serial.print(d);
Serial.print("s\t");
//printing temperature sensor values
//Serial.print("temperature : ");
//Serial.print(temp);
//Serial.println("f");
delay(2000);//delay of 2 seconds
My code is working because, with the cable connection, I received the data : 1s ; 1s2 ;...
But when I choose the Port corresponding with the HC05, it doesn't work.
Someone can help me ?
It is possible that I forgot some information, do not hesitate to ask them.
Thank you very much,
Franzouille
