HC-05 did not read correct data from Android app
0
down vote
favorite
I have made a home automation project where am using an Arduino Uno and HC-05 Bluetooth module and an Android app. I did everything properly but when I send commands from my Android app it works sometimes and sometimes it doesn’t work.
I checked these commands on the serial monitor and found that data command I recieve at serial monitor did not match the commands which I send from my Android app. For example my Android app send command “ON1” but on serial monitor it shows “OL1?”. I thought it might be a problem with the HC-05 so I changed it and used a new HC-05 module, but the problem is still there.
This time I checked the commands from another Android app (Bluetooth Terminal HC-05) and there was the same problem. Sometimes it read the command correctly app and sometimes it read something else.
I am so confused weather the problem is in my hardware side or software side.I tried a lot but didn’t get any solution about my problem anywhere. Can anybody help me please?
This is the Arduino code of my project:
#include <SoftwareSerial.h>
SoftwareSerial Genotronex(2, 3); //TX, RX  pins of arduino respetively
String command;
 Genotronex.begin(9600);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(9, OUTPUT);
  while (Genotronex.available()){  //Check if there is an available byte to read
  delay(10); //Delay added to make thing stable
  char c = Genotronex.read(); //Conduct a serial read
  command += c; //build the string.
  if (command.length() > 0) {
    Serial.print(command);
  if(command == "ON1") //this command will be given as an input to switch on light1
    digitalWrite(9, HIGH);
  else if(command == "OFF1") //this command will be given as an input to switch off light1 simillarly other commands work
    digitalWrite(9, LOW);
  else if (command == "ON2")
    digitalWrite (10, HIGH);
  else if ( command == "OFF2")
   digitalWrite (10, LOW);
  else if (command == "ON3")
   digitalWrite (11, HIGH);
  else if (command == "OFF3")
   digitalWrite (11, LOW);
 else if (command == "ON4")
   digitalWrite (12, HIGH);
  else if (command == "OFF4")
   digitalWrite (12, LOW);
 else if (command == "ON5")
   digitalWrite (13, HIGH);
  else if (command == "OFF5")
   digitalWrite (13, LOW);
  else if (command == "all on") //using this command you can switch on all devices
   digitalWrite (9, HIGH);
  else if (command == "off")//using this command you can switch off all devices
   digitalWrite (9, LOW);
command="";}} //Reset the variable
