HC-05 doesn't respond on AT Mode.
Hello fellows,
I plug the HC-05 module on Arduino Due, press the little button, start everything pluggin that on USB and the blinking pattern indicates that it is on AT Mode (Blinking at 1Hz rate). I then send Serial Monitor commands but I get no response!
It is not burned since it responds with the blinking pattern. I can see the HC-05 with my smartphone, I can connect to it using the default PIN "1234" and it changes the blinking pattern again. So I think it is working.
What am I doing wrong??
Serial1 on due is 18,19 pins.
String command = "";
  Serial.println("Type commands for AT:");
  Serial1.begin(38400);
  if (Serial.available())
    while (Serial.available()) {
      command += (char)Serial.read();
    delay(10);
    Serial1.println(command);
  command = "";
  if (Serial1.available())
    while (Serial1.available()) {
      command += (char)Serial1.read();
    delay(10);
    Serial.println(command);
  command = "";
The default baud rate for HC-05 is 9600 baud. So unless you've changed this with AT- commands you will run into issues.
DON'T CROSS-POST!!!!!!!!!!!!!!!! http://forum.arduino.cc/index.php?topic=474065 REPORTED
What do I do when there are 2 subjects included? May be a Due issue, or a general communication Issue...
I've tried all the baudrates... No response.
Chose the most appropriate subject.
Just passing by to confess my intellectual smallness.
I was connecting HC-05 RX to Arduino RX and HC-05 TX to Arduino Tx.
After the wiring fixed everything works great.
Sorry for the inconvenience.
Thanks!
