right now, i need to disconnect the hc-05 from the Rx and Tx pins for every upload. is there a way to avoid the need to do that?
Why not use the HC-05 to do the upload?
TheMemberFormerlyKnownAsAWOL:
how so? im not familiar with how to do that.
vortix2950:
You shouldn't connect a BT module to those pins, because they are hard-wired the the USB<>Serial chip.
Use the BT module with SoftwareSerial on two different pins.
Leo..
Wawa:
Leo..
does using these pins cause more issue other than the problem with the upload? is there other reason why its a bad idea? i have been using the module that way for a while and it seems fine.
Didn't say you can't, but expect upload and/or printing errors if you do.
SoftwareSerial on different pins solves that problem.
Examples in the IDE.
Leo..
