I'm using flutter for my mobile application. I want to connect my mobile app with Arduino using HC-05 module.
My flutter code (a small piece of code out of a big code):
class HomeLayout extends StatefulWidget {
const HomeLayout({super.key});
@override
State<HomeLayout> createState() => _HomeLayout();
class _HomeLayout extends State<HomeLayout> {
void _scanDevices() async {
List<BluetoothDevice> devices = <BluetoothDevice>[];
print('scan started');
try {
devices = await FlutterBluetoothSerial.instance.getBondedDevices();
} catch (ex) {
print("Error: $ex");
print('scan ended');
print(devices);
for (BluetoothDevice device in devices) {
print(device.address); // This will print the MAC address of each bonded device
Future<bool> _connectToBluetooth() async {
//_scanDevices();
print('\n\nConnecting to the device');
String address='my hc05 mac address';
try {
connection = await BluetoothConnection.toAddress(address);
} catch(ex){
print("Error : $ex");
return false;
print('Connected to the device');
return true;
//receiveData();
void receiveData() async{
bool check = await _connectToBluetooth();
print("\n\nReceiving Data");
if(check) {
List<int> _dataBuffer = <int>[];
connection!.input!.listen((Uint8List data) {
setState(() {
_dataBuffer.addAll(data);
print("Data : " + data.toString());
print("Received Data");
Widget build(BuildContext context) {
receiveData();
My arduino code:
SoftwareSerial mySerial(10, 11);
void setup(){
mySerial.begin(38400);
void loop(){
int sound_sensor = analogRead(A1);
light_sensor = analogRead(A0);
mySerial.write("light sensor : ");
mySerial.write(light_sensor);
mySerial.write("sound sensor : ");
mySerial.write(sound_sensor);
When I run my flutter code, it asks for Location (as to scan the available bluetooth devices).
My HC-05 module blinks as usual when i power my arduino and HC-05 (in red and blue colour). Then after 2/3 seconds, blue light disappears. then after a while, both the lights are on (doesn't blink).
And my flutter code returns an error:
PlatformException(connect_error, read failed, socket might closed or timeout, read ret: -1, java.io.IOException: read failed, socket might closed or timeout, read ret: -1
I/flutter (25783): at android.bluetooth.BluetoothSocket.readAll(BluetoothSocket.java:845)
I/flutter (25783): at android.bluetooth.BluetoothSocket.readInt(BluetoothSocket.java:859)
I/flutter (25783): at android.bluetooth.BluetoothSocket.connect(BluetoothSocket.java:436)
I/flutter (25783): at io.github.edufolly.flutterbluetoothserial.BluetoothConnection.connect(BluetoothConnection.java:57)
I/flutter (25783): at io.github.edufolly.flutterbluetoothserial.BluetoothConnection.connect(BluetoothConnection.java:64)
I/flutter (25783): at io.github.edufolly.flutterbluetoothserial.FlutterBluetoothSerialPlugin$FlutterBluetoothSerialMethodCallHandler.lambda$onMethodCall$4$io-github-edufolly-flutterbluetoothserial-FlutterBluetoothSerialPlugin$FlutterBluetoothSerialMethodCallHandler(FlutterBluetoothSerialPlugin.java:1007)
I/flutter (25783): at io.github.edufolly.flutterbluetoothserial.FlutterBluetoothSerialPlugin$FlutterBluetoothSerialMethodCallHandler$$ExternalSyntheticL
Kindly help me to figure out why this error occurs and a way to get rid of it.
