HC-05 problem
hello I use a hc-05 hc-05 is connected correctly I can not log in AT mode but I can not communicate through the serial port of Arduino i use an Arduino two for this experience the communication baud rate are both set to 38400 baud help please let I also set the com from windos to 38400 settings but it does not work
No you use an Arduino Due not a "two" your translator got that wrong.
You would not be the first person that thought there was nothing wrong with the connections when there was, so show the schematic.
You are going to have to explain that a bit better please.
I communicate with Arduino via serial port ( com 4 for my pc ) and to send the data for hc - 05 it copies the data entered on the serial port and send them on serial2 arduino . Tomorrow I enclose a copy of the program can not tonight . thanks giggi
Rx to tx2 arduino Tx to rx2 arduino Key (have a button) to vcc Vcc to vcc Gnd to gnd
