HC-05 Serial data issue
I am learnig about how to use the HC-05. I’ve wrotten the code and it works recieving the data, but when I hold any button the data changes
(I’ve delcared some buttons as 1 and 3, but if I hold any of them the data appears as -30009)
tanque.ino (897 Bytes)
DiegoLeone42:
I am learnig about how to use the HC-05. I've wrotten the code and it works recieving the data, but when I hold any button the data changes
(I've delcared some buttons as 1 and 3, but if I hold any of them the data appears as -30009)
What button?
ieee488:
What button?
The buttons are in a bluetooth controller app
DiegoLeone42:
So we are supposed to guess what the app is and what the buttons are intended to do?
Sorry, my crystal ball is lost in the snow today.
...R
Serial Input Basics - simple reliable ways to receive data.
Robin2:
...R
Robin2:
...R
Well... I am "controlling" motors for a car, so the controller has declared the variables by this way:
-up arrow :1
-Right arrow: 2
-Down arrow: 3
-Left arrow: 4
The problem is when I try to read the data from the Serial1 port. If I hold any button the variable value increases (like 234000) instead of showing the real value
(the program is:
if(Serial.available ()>0){
(Serial.read());
if(Serial1.available ()>0){
(Serial1.read());
int dir= Serial1.readString().toInt();
Serial.print("dir:");
Serial.println(dir);
//"dir" is for Direction)
DiegoLeone42:
Serial.print(“dir:”);
//“dir” is for Direction)
I suspect the problem is that your readString() function is treating a succession of values as a single number and if it converts a number bigger than 32767 to an int it will show as a negative value.
Can you get your sending program to send the data like this “<1>” and “<2>” etc. If so, the 3rd example in my link will receive the data reliably.
Even if you can’t change the data format study my link carefully. The first example may work - but it won’t be as reliable.
…R
