HC-05 stops communicating after 3 minutes
I am using an Arduino Uno and Nano and 2 hardcoded hc-05’s bluetooth(master and slave that only connect to each other) - in order to turn on a led(connected to the slave) through a button(connected to the master). The rate is 38400 for both.
It works perfectly when starting or when sending data once in a while, but when leaving the system idle after about 3 minutes, it stops working - you can see the data being sent and hc-05 blinking correctly.
When reconnecting one of the Arduinos everything works again as usual.
Any ideas? Mabye some buffer needs to be cleaned?
The master code:
int ledPin = 6;
int data=0;
int button = 8;
int buttonState = 0;
Serial.begin(38400);
pinMode(ledPin, OUTPUT);
if (Serial.available() > 0)
data = Serial.read();
buttonState = digitalRead(button);
if (buttonState == HIGH) {
Serial.write(‘1’); // Sends ‘1’ to the slave to turn on LED
digitalWrite(ledPin, HIGH); // LED ON
delay(300);
else {
Serial.write(‘0’);
digitalWrite(ledPin, LOW); // LED OFF
The slave code:
int ledPin = 4;
int data=0;
Serial.println(data);
// Controlling the LED
if (data == ‘1’) {
delay(300);
else if (data == ‘0’) {
Thanks :slight_smile:
BTHC05_master.ino (957 Bytes)
BTHC05_slave.ino (452 Bytes)
