HC-05 TO HC-06 communication
okie dokie,
what i have is: a custom controller w/ an HC-05 THAT WORKS
and a HC-06 on an UNO that again... WORKS
i'm just clarifying that this not a hardware issue because i don't want this devolving into AT blah blah.
both modulus can communicate with TeraTerm,
i can pass characters from ((serial monitor > controller > HC-05 > HC-06 > UNO > TeraTerm)) and back again.
what i'm haveing problems with is figguring out how to pass values from the controler to the UNO via the bluetooth so that i can build a rc car outa balsa wood or something.
i'm guessing that the problem is in how i'm passing the values, or not acounting for some protocall
this is for the HC-05 (sending unit)
//value is bool
//writtin is int
  buttonState = digitalRead(button);
    if(buttonState == 1){
      value = !value;
      if(bluetooth.available()){
        for(int i = 0; i > 1000; ++i){
        writtin = (byte) bluetooth.write(7);
        delay(1);}}
      hold();
      lcdSetCursor(20);
      if(value == 1){lcd.write("ON ");}
                else{lcd.write("OFF");}
                     lcd.write("%d",writtin);  //was trying to see how meany bytes 'bluetooth.write()' sent
and for the HC-06 (receving)
void loop() // run over and over
   if(mySerial.available() >= 0){
    money = mySerial.read();         //money is an int value
   if(money == 7){pin13 = !pin13;}   //pin13 is a bool value
   digitalWrite(13, pin13);
   money = 0;
   delay(1200);
thoughts?
well thanx alot ppl, been real chatty,
send code ((sorry i’m pulling this from a controler with a menu and lcd)mainly 2 buttons + bluetooth)
void testBot(){//////////////////////////////////////////////void setup///
  lcdClearDisplay();
  lcd.write("TEST OF ROBOTS                          OFF");
  bluetooth.begin(9600);
  digitalWrite(9, HIGH);
  boolean value = 0;
  int writtin = 0;
  hold();
  while(upButtonState != HIGH){///////////////////////////////void loop///
      value = !value;
        bluetooth.write(7);
        delay(1);}
      hold();
      lcdSetCursor(20);
  upButtonState = digitalRead(upButton);}
bluetooth.end();
digitalWrite(9, LOW);
receve
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 10 (connect to TX of other device)
 * TX is digital pin 11 (connect to RX of other device)
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created back in the mists of time
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(6, 7); // RX, TX
boolean pin13 = 1;
int count = 0;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
 pinMode(13, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
// delay(1000);
//  for(int i = 0; i<7; ++i){
//   pin13 = !pin13;
//   digitalWrite(13, pin13);
//  delay(300);}
 delay(10);
   if(mySerial.available()){
    byte tempChar = mySerial.read();
    if(tempChar == B111){pin13 = !pin13;}
    tempChar = 0;
and onto building balsawood RC cars lol!!
