HC-06 AT command issue
Hi, I've tried to use AT command "AT+NAME" on bluetooth module HC-06 but it always return only "OK". I'm using gtkterm and a usb to rs232 adapter. Thanks
That is all it will return but the name would have been changed.
No, the name doesn't change
With this command AT+NAME you set the new name in module you don't get the current name of module, so as dear Grumpy_Mike said you will get the OK as feedback.
The command should be like:
AT+NAME=NewName
or
AT+NAMENewName
I thing is the first, so after that do a search from laptop or phone or ... and you will see the name "NewName"
Good luck :slight_smile:
There the problem is that the serial return always OK without the inputted name and it don't keep the new name.
I do a quick search on google and found this nice tutorial http://www.psychicorigami.com/2014/03/22/re-configuring-the-hc-06-cheap-bluetooth-serial-module/
I hope it will help you because has picture's on each step (in case you do something wrong) :wink:
