HC 06 data receiving
Hello!
I've wrote a script in python which sends data through PC's bluetooth to HC-06 on arduino.
state is integer from 0 to 1000 (it is controlled through potentiometer)
gaugeSocket.send(str(state))...
I have a problem, because I can't get right character to integer conversion on arduino (from HC-06 serial).
SoftwareSerial mySerial(10, 11); // RX, TX
char buf[2];
int i=0;
int data;
int ledPin = 9;
    pinMode(ledPin, OUTPUT);
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  mySerial.begin(9600);
void loop() { // run over and over
  if (mySerial.available()) {
    for(;i<2;){
      buf[i] = mySerial.read();
      i++;
    i = 0;
    Serial.print(buf);
    data = atoi(buf);
    analogWrite(ledPin, data/10); //To see how code behaves on LED
This is the output (from Serial.print(buf)):
0ÿ(0ÿ(0ÿ(0ÿ(0ÿ(0ÿ(0ÿ(60(1ÿ(00(16(0ÿ(23(0ÿ(30(0ÿ(3ÿ(60(43(0ÿ(49(0ÿ(53(0ÿ(5ÿ(90(69(0ÿ(88(0ÿ(10(00(10(00(10(
if I turn the potentiometer from 0 to 1000.
What am I missing?
Thank you
The usual - check that there's a character to read, and then read both of them.
Hello,
Is it me or is the OP using two different serial read numbers? 9600 and 57600?
Also, atoi works only C style strings.
PilotinControl:
Hello,
So?
Different interfaces.
AWOL thanks for your answer, but can you be more specific please?
Interface 1 SoftwareSerial mySerial(10, 11);
Interface 2   Serial.begin(57600);
No, I meant with this:
"The usual - check that there's a character to read, and then read both of them."
    for(;i<2;){
      i++;
Check to see there's at least one character to read, then read both of them.
I can't really see how more specific I could be.
