HC-06 Level shifting
Hi, im trying to build a bridge between a 433MHZ serial radio and a HC06 Bluetooth radio. the 433MHZ radio works on 3v3 and the HC on 5v. im using a level converter but when i send something from another 433 radio, the HC-06 receives it and i can see it on my phone. but when i try to send something with my ohnoe to the radio, nothing happens.
why? and how can i solve it?
thanks, Jonas
CodingGhost: why?
It probably hasn't anything to do with levels. An HC-06 may run on 5v, but the Rx and Tx both run at 3.3v
so any other solutions?
What, exactly, is an "ohnoe"?
Did you forget to post your code? Or, did you use a 0 point font?
