Hi guys, I have a some problem using the HC-12. One of it sends a binary dataset and another ones just receives numbers 0 or 128 or 255. My question is why? Yet converted to binary, char, string and so much another which I tryied? To sender the sketch used was:
float temp = bmp.readTemperature();
float pressao = bmp.readPressure();
pressao = pressao / 101325; // convertendo de Pa para ATM
float umidade = dht.readHumidity();
umidade = umidade - 100;
float batt = readVcc();
float alti = bmp.readAltitude();
t = (int)(temp1e2);
p = (int)(pressao 1e3);
u = (int)(umidade1e2);
b = (int)(batt);
l = (int)(alti 1e2);
TX[0] = t/256;
TX[1] = t%256;
TX[2] = p/256;
TX[3] = p%256;
TX[4] = u/256;
TX[5] = u%256;
TX[6] = b/256;
TX[7] = b%256;
TX[8] = l/256;
TX[9] = l%256;
for(int i=0; i<n; i++)
HC12.write(TX[i]);
The receiver code is:
while(HC12.available()>0)
RX[i] = HC12.read();
temp = ((RX[0]*256) + RX[1]) / 1e2;
pres = ((RX[2]*256) + RX[3]) / 1e3;
umi = ((RX[4]*256) + RX[5]) / 1e2;
bat = ((RX[6]*256) + RX[7]) / 1e0;
alt = ((RX[8]*256) + RX[9]) / 1e2;
Maybe: the receiver checks if there is one or more bytes available to read; but you read N bytes regardless if there is one or two or N bytes available.
Can you please edit your post, select the code and click the < / > button just above the text box; this will add the code tags. Next save the post.
We also prefer complete code, not snippets; there might be other things wrong in your code. In the IDE, use edit -> copy for forum; this will copy the code (including code tags) to the clipboard. Next paste the code in a reply.
@nazlob2019 , your topic has been moved to a more suitable location on the forum.
You probably mean:
if (HC12.available() >= n)
Ok, that's fine. Could you give me the link? Thank you for your attention.
I'm new one here.
[THIS IS THE TRANSMITTER CODE]
#include <Adafruit_Sensor.h> //INCLUSÃO DE BIBLIOTECA
#include <Adafruit_BMP280.h> //INCLUSÃO DE BIBLIOTECA
#include <SPI.h>
#include <Wire.h>
#include <SoftwareSerial.h>;
#include <DHT.h> // Biblioteca para DHT temp e umidade
#define dht_dpin A0
#define DHTTYPE DHT11
SoftwareSerial HC12(2, 3);
DHT dht(dht_dpin, DHTTYPE); // Inicializa o sensor de temperatura e umidade
Adafruit_BMP280 bmp; //OBJETO DO TIPO Adafruit_BMP280 (I2C)
int n = 10;
byte TX[10];
unsigned long time = millis();
unsigned long data, hora;
float temp = 0, pressao=0;
float umidade=0, batt=0;
float lati, longi, alti;
int p=0, t=0, b=0, u=0;
int l=0, ll=0;
double al, vel;
float te, pr, um, ba;
HC12.begin(9600);
pinMode(8,OUTPUT);
digitalWrite(8,HIGH);
Serial.println("Iniciando..."); //IMPRIME O TEXTO NO MONITOR SERIAL
if(!bmp.begin(0x76))
{ //SE O SENSOR NÃO FOR INICIALIZADO NO ENDEREÇO I2C 0x76, FAZ
Serial.println(F("Sensor BMP280 não foi identificado! Verifique as conexões.")); //IMPRIME O TEXTO NO MONITOR SERIAL
while(1); //SEMPRE ENTRE NO LOOP
Serial.println("BMP OK!"); //IMPRIME O TEXTO NO MONITOR SERIAL
long readVcc()
long result;
// Read 1.1V reference against AVcc
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Convert
while (bit_is_set(ADCSRA,ADSC));
result = ADCL;
result |= ADCH<<8;
result = 1125300L / result; // Back-calculate AVcc in mV
return result;
t = (int)(temp*1e2);
p = (int)(pressao*1e3);
u = (int)(umidade*1e2);
b = (int)(batt);
l = (int)(alti*1e2);
String msg = String(temp) + ", " + String(pressao) + ", " + String(umidade) + ", " + String(batt) + ", " + String(alti);
TX[0] = t/256;
TX[1] = t%256;
TX[2] = p/256;
TX[3] = p%256;
TX[4] = u/256;
TX[5] = u%256;
TX[6] = b/256;
TX[7] = b%256;
TX[8] = l/256;
TX[9] = l%256;
// Serial.println(TX[0]);
// Serial.println(TX[1]);
// Serial.println(TX[2]);
// Serial.println(TX[3]);
// Serial.println(TX[4]);
// Serial.println(TX[5]);
// Serial.println(TX[6]);
// Serial.println(TX[7]);
// Serial.println(TX[8]);
// Serial.println(TX[9]);
// for(int i=0; i<n; i++)
// HC12.write(TX[i]);
HC12.print(temp);
HC12.println(" ");
HC12.print(pressao);
HC12.print(" " );
HC12.print(umidade);
HC12.print(" ");
HC12.print(alti);
HC12.println(" ");
HC12.print(batt);
HC12.println(" ");
Serial.print("Temperatura : " );
Serial.print(temp );
Serial.println(" *C");
Serial.print("Pressao : " );
Serial.print( pressao );
Serial.println(" atm");
Serial.print("Umidade : " );
Serial.print( umidade );
Serial.println(" %");
Serial.print("Alt. : ");
Serial.print(alti);
Serial.println(" m");
Serial.print("Bat. : ");
Serial.print(batt);
Serial.println(" mV");
Serial.println("");
delay(3000);
[/code]
[THIS IS THE RECEIVER CODE]
/***CONFIGURATION ****/
const long interval = 5000; // ms
const int slaves = 1; //Number of slaves (max 16) (go to line 95 and complete the if statement for every sensor)
//Libraries
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
SoftwareSerial HC12(5, 6); // RX, TX
float temp = 0, bat = 0, alt = 0;
float umi = 0, pres = 0;
float lati = 0, longi = 0;
char incomingByte, msg;
String command;
int n = 10;
byte RX[10];
HC12.begin(9600);
pinMode(7,OUTPUT);
digitalWrite(7,HIGH);
lcd.begin();
lcd.setCursor(5,0);
lcd.print("LAFEJ");
lcd.setCursor(2,1);
lcd.print("Aguardando...");
lcd.setCursor(5,0);
lcd.print("LAFEJ");
lcd.setCursor(2,1);
lcd.clear();
RX[i] = 0; // Zerar todas as posições para renovar valores
while(HC12.available()>=n)
float v = map(RX[i], 0, 255, 0, 1023);
Serial.print(v);
Serial.print(" --> ");
Serial.print("RX[i] = ");
Serial.print(RX[i]);
Serial.print(" i = ");
Serial.println(i);
Serial.println("FORA DO LOOP");
Serial.println(RX[0]);
Serial.println(RX[1]);
Serial.println(RX[2]);
Serial.println(RX[3]);
Serial.println(RX[4]);
Serial.println(RX[5]);
Serial.println(RX[6]);
Serial.println(RX[7]);
Serial.println(RX[8]);
Serial.println(RX[9]);
temp = ((RX[0]*256) + RX[1]) / 1e2; // LSB
Serial.print("Temperatura : ");
Serial.print( temp );
Serial.print("Pressao : ");
Serial.print( pres );
Serial.print("Umidade : ");
Serial.print( umi );
Serial.print("Bateria : ");
Serial.print( bat );
Serial.println(" V");
Serial.print("Altitude : ");
Serial.print( alt );
Serial.println("");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("TEMP : ");
lcd.setCursor(7,0);
lcd.print(temp);
lcd.setCursor(12,0);
lcd.print(" C");
lcd.setCursor(0,1);
lcd.print("UMID : ");
lcd.setCursor(7,1);
lcd.print(umi);
lcd.setCursor(12,1);
lcd.print(" % ");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("BAT : ");
lcd.setCursor(7,0);
lcd.print(bat);
lcd.setCursor(11,0);
lcd.print(" V ");
lcd.setCursor(0,1);
lcd.print("PRES : ");
lcd.setCursor(7,1);
lcd.print(pres);
lcd.setCursor(11,1);
lcd.print(" atm");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("ALT. : ");
lcd.setCursor(7,0);
lcd.print(alt);
lcd.setCursor(13,0);
lcd.print(" m ");
lcd.setCursor(0,1);
lcd.print("");
lcd.setCursor(7,1);
lcd.print("");
lcd.setCursor(13,1);
lcd.print("");
lcd.clear();
[/code]
Hi John, thank you for your reply. So, I modified according to you but didn't work yet.
// [THIS IS THE TRANSMITTER CODE]
#include <SPI.h>
#include <Wire.h>
#define dht_dpin A0
const int n = 10;
byte TX[n];
HC12.begin(9600);
pinMode(8, OUTPUT);
digitalWrite(8, HIGH);
if (!bmp.begin(0x76))
while (1); //SEMPRE ENTRE NO LOOP
long readVcc()
long result;
while (bit_is_set(ADCSRA, ADSC));
result = ADCL;
result |= ADCH << 8;
return result;
uint16_t t = temp * 1e2;
uint16_t p = pressao * 1e3;
uint16_t u = umidade * 1e2;
uint16_t b = batt;
uint16_t l = alti * 1e2;
TX[0] = highByte(t);
TX[1] = lowByte(t);
TX[2] = highByte(p);
TX[3] = lowByte(p);
TX[4] = highByte(u);
TX[5] = lowByte(u);
TX[6] = highByte(b);
TX[7] = lowByte(b);
TX[8] = highByte(l);
TX[9] = lowByte(l);
for (int i = 0; i < n; i++)
HC12.write(TX[i]);
Serial.print(alti);
Serial.print(batt);
Serial.println("");
delay(3000);
//[THIS IS THE RECEIVER CODE]
//Libraries
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
String command;
const int n = 10;
byte RX[n];
HC12.begin(9600);
pinMode(7, OUTPUT);
digitalWrite(7, HIGH);
lcd.begin();
lcd.setCursor(5, 0);
lcd.print("LAFEJ");
lcd.setCursor(2, 1);
lcd.print("LAFEJ");
lcd.clear();
Serial.print("RX[");
Serial.print(i);
Serial.print("]: ");
Serial.println(RX[i]);
float temp = ((RX[0] * 256) + RX[1]) / 1.0e2;
float pres = ((RX[2] * 256) + RX[3]) / 1.0e3;
float umi = ((RX[4] * 256) + RX[5]) / 1.0e2;
float bat = ((RX[6] * 256) + RX[7]);
float alt = ((RX[8] * 256) + RX[9]) / 1.0e2;
Serial.println("");
lcd.clear();
lcd.setCursor(0, 0);
lcd.setCursor(7, 0);
lcd.print(temp);
lcd.setCursor(12, 0);
lcd.print(" C");
lcd.setCursor(0, 1);
lcd.setCursor(7, 1);
lcd.print(umi);
lcd.setCursor(12, 1);
lcd.print(" % ");
lcd.clear();
lcd.print(bat);
lcd.setCursor(11, 0);
lcd.print(" V ");
lcd.print(pres);
lcd.setCursor(11, 1);
lcd.print(" atm");
lcd.clear();
lcd.print(alt);
lcd.setCursor(13, 0);
lcd.print(" m ");
lcd.print("");
lcd.print("");
lcd.setCursor(13, 1);
lcd.print("");
lcd.clear();
system
Closed
September 11, 2021, 10:58am
10
