HC-12 not sleeping
Hello all,
I am measuring the current to my HC-12 module and it is steady at 14-15 mA whether in sleep mode or not. I do get an "OK+SLEEP" response from the module so I believe it is receiving the command ok. I am sure it is something really simple but I can't quite spot it. Any help would be greatly appreciated. I can see a drop in current for a split second when I send the sleep command so I think it may be waking up immediately for some reason. Here is stripped-down version of my code:
#include <SoftwareSerial.h>
#define HC12_SET 5
#define HC12_TX 10
#define HC12_RX 11
SoftwareSerial HC12(HC12_TX, HC12_RX);
void HC12_Sleep()
	digitalWrite(HC12_SET, LOW);            // Enter command mode
 	delay(100);                             // Allow chip time to enter command mode
 	HC12.print("AT+SLEEP");             	// Send command
 	delay(200);                             // Wait for a response
  	digitalWrite(HC12_SET, HIGH);         // Exit command / enter transparent mode
void HC12_Wake()
 	digitalWrite(HC12_SET, HIGH);         // Exit command mode
 	delay(100);                             // Delay before proceeding
	pinMode(HC12_SET,OUTPUT);
	HC12.begin(9600);
	HC12_Sleep();
	HC12.end();
	HC12.begin(9600);
	HC12_Sleep();
	HC12.end();
	delay(5000);
	return;
Why did you run a HC12.begin() and .end() in every loop cycle?
Also you never have to call return in the Arduino loop() function.
Try this code and measure the HC-12 current:
#define HC12_SET 5
#define HC12_TX 10
#define HC12_RX 11
void HC12_Sleep()
	HC12.begin(9600);
	HC12_Sleep();
Try this
#define HC12_SET 5
#define HC12_TX 10
#define HC12_RX 11
void HC12_Sleep()
void HC12_Wake()
	HC12.begin(9600);
	//HC12_Sleep(); <-- delete this
	//HC12.end(); <-- delete this
	//HC12.begin(9600); <-- delete this
	HC12_Sleep();
	delay(5000);
	//return; <-- delete this
    HC12_Wake();
    delay(5000);
Hey guys,
Thanks for your replies. I tried both very sketches and neither work. When I call sleep, the current drops to 0.05 mA for a split second, then goes right back to 15 mA. Very frustrating. Same result with three different modules. And when I check the return from AT+SLEEP I get the proper response so I know things are communicating.
I have a new HC-12 on order. Maybe I got a bad batch...but you know you are desperate when you are swapping hardware.
Please show you resulting code
Here it is. Can't get much simpler. I received a new HC12 today. Same result. Thanks alot for looking at this. It must be something very simple...
// HC-12_sleep.ino
#define HC12_SET	5
#define HC12_TX	10
#define HC12_RX	11
SoftwareSerial HC12(HC12_TX, HC12_RX); // HC-12 TX Pin, HC-12 RX Pin
void HC12_Sleep()
	delay(100);
 	delay(200);
void HC12_Wake()
 	delay(100);
 	delay(100);
	HC12.begin(9600);
	HC12_Sleep();
	HC12_Sleep();
	delay(3000);
	HC12_Wake();
	delay(3000);
	return;
You never have to call return in the Arduino loop() function.
As for code - try to add line feed after the command:
By "add a line feed" - I am guessing you meant to the SLEEP string as in "AT+SLEEP\n". That had no effect.
Removing the loop() return had no effect but that makes sense as the return in a void function in C is optional\implied.
I am really stumped. I will see if I can send AT commands directly from the serial monitor and see what that does.
