Hello there! This is my case
I´ve been trying to make ServoX and ServoY work simultaneously:
ServoX: Sweeps a 180° in 3 seconds, back and forth without stopping (first i wanted to make a 1 second stop before moving in the other direcion, but it was too complicated to me)
ServoY: moves from 90 to 180 degrees depending on the distance read by the sensor, I used the map and constrain functions.
The two servos work well separately, and as expected, the problem comes when "fusing" them, I even learned how tu use the millis function instead of delay.
Could someone check the code please?
ULTRASERVO_V2.ino (1.36 KB)
