HC-SR04 code for ESP32 with multiple channel support
If anyone uses ESP32 - it is possible to very easily control ultrasonic sensor HC-SR04 with esp hardware RMT features with up to 8 channels so up to 8 sensors can be connected at the same time
I wrote a simple code - seems to work but needs to be tested more
Accuracy is very good and response very fast
#include <stdio.h>
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "freertos/semphr.h"
#include "esp_err.h"
#include "esp_log.h"
#include "driver/rmt.h"
#include "driver/periph_ctrl.h"
#include "soc/rmt_reg.h"
#include <sys/time.h>
#include "driver/gpio.h"
#define RMT_TX_CHANNEL          1           /* RMT channel for transmitter */
#define RMT_TX_GPIO_NUM         PIN_TRIGGER /* GPIO number for transmitter signal */
#define RMT_RX_CHANNEL          0           /* RMT channel for receiver */
#define RMT_RX_GPIO_NUM         PIN_ECHO    /* GPIO number for receiver */
#define RMT_CLK_DIV             100         /* RMT counter clock divider */
#define RMT_TX_CARRIER_EN       0           /* Disable carrier  */
#define rmt_item32_tIMEOUT_US   9500        /*!< RMT receiver timeout value(us) */
#define RMT_TICK_10_US          (80000000/RMT_CLK_DIV/100000)   /* RMT counter value for 10 us.(Source clock is APB clock) */
#define ITEM_DURATION(d)  ((d & 0x7fff)*10/RMT_TICK_10_US)
#define PIN_TRIGGER 18
#define PIN_ECHO 19
static void HCSR04_tx_init()
    rmt_config_t rmt_tx;
    rmt_tx.channel = RMT_TX_CHANNEL;
    rmt_tx.gpio_num = RMT_TX_GPIO_NUM;
    rmt_tx.mem_block_num = 1;
    rmt_tx.clk_div = RMT_CLK_DIV;
    rmt_tx.tx_config.loop_en = false;
    rmt_tx.tx_config.carrier_duty_percent = 50;
    rmt_tx.tx_config.carrier_freq_hz = 3000;
    rmt_tx.tx_config.carrier_level = 1;
    rmt_tx.tx_config.carrier_en = RMT_TX_CARRIER_EN;
    rmt_tx.tx_config.idle_level = 0;
    rmt_tx.tx_config.idle_output_en = true;
    rmt_tx.rmt_mode = 0;
    rmt_config(&rmt_tx);
    rmt_driver_install(rmt_tx.channel, 0, 0);
static void HCSR04_rx_init()
    rmt_config_t rmt_rx;
    rmt_rx.channel = RMT_RX_CHANNEL;
    rmt_rx.gpio_num = RMT_RX_GPIO_NUM;
    rmt_rx.clk_div = RMT_CLK_DIV;
    rmt_rx.mem_block_num = 1;
    rmt_rx.rmt_mode = RMT_MODE_RX;
    rmt_rx.rx_config.filter_en = true;
    rmt_rx.rx_config.filter_ticks_thresh = 100;
    rmt_rx.rx_config.idle_threshold = rmt_item32_tIMEOUT_US / 10 * (RMT_TICK_10_US);
    rmt_config(&rmt_rx);
    rmt_driver_install(rmt_rx.channel, 1000, 0);
void app_main()
    HCSR04_tx_init();
    HCSR04_rx_init();
    rmt_item32_t item;
    item.level0 = 1;
    item.duration0 = RMT_TICK_10_US;
    item.level1 = 0;
    item.duration1 = RMT_TICK_10_US; // for one pulse this doesn't matter
    size_t rx_size = 0;
    RingbufHandle_t rb = NULL;
    rmt_get_ringbuf_handle(RMT_RX_CHANNEL, &rb);
    rmt_rx_start(RMT_RX_CHANNEL, 1);
    double distance = 0;
    for(;;)
        rmt_write_items(RMT_TX_CHANNEL, &item, 1, true);
        rmt_wait_tx_done(RMT_TX_CHANNEL, portMAX_DELAY);
        rmt_item32_t* item = (rmt_item32_t*)xRingbufferReceive(rb, &rx_size, 1000);
        distance = 340.29 * item->duration0 / (1000 * 1000 * 2); // distance in meters
        printf("Distance is %f cm\n", distance * 100); // distance in centimeters
        vRingbufferReturnItem(rb, (void*) item);
        vTaskDelay(200 / portTICK_PERIOD_MS);
