HC SR04 distance sensor with servo
I want to control the action of a Servo with the read distance from the HC SR04 module. When an object is within 100 cm from the sensor, the sensor will turn a few times. If the distance > 100cm then the servo sets itself to 0.
The problem is that it is not working. The Servo moves a little en then stops. I need a little help in this!
This is my code:
#include <Servo.h>
Servo head2;  // create servo object to control a servo
                // twelve servo objects can be created on most boards
int pos = 90;    // variable to store the servo position
 //afstandsmeter
const int influence = 50; // Distance for action
const int echoPin = 7;
const int trigPin = 8;
int maximumRange = 500;
int minimumRange = 0;
long duration, distance;
int obstacle = afstand();  //afstand=distance in dutch
  head2.attach(9);  // attaches the servo on pin 9 to the servo object
//afstandssensor
 Serial.begin (9600);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
  delay(100);
  afstand();
  if(obstacle>influence)
  turnhead();
if(obstacle<influence){
  head2.write(0);
 Serial.println(distance);
  delay(5000);
void turnhead(){
   for(pos = 90; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    head2.write(pos);              // tell servo to go to position in variable 'pos'
    delay(10);                     // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=0; pos-=1)     // goes from 180 degrees to 0 degrees
 for(pos = 0; pos <= 90; pos += 1) // goes from 0 degrees to 180 degrees
long afstand(){
  /* The following trigPin/echoPin cycle is used to determine the
 distance of the nearest object by bouncing soundwaves off of it. */
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 //Calculate the distance (in cm) based on the speed of sound.
 distance = duration/58.2;
 distance = constrain(distance, 0, 500);
 return duration / 58.2;
Do you have adequate power supply to the servo ?
You cannot power the servo from the arduino.
The first thing I would try, is making a call to your turnhead( ) function from setup( ), before doing any of the distance-checking stuff.
This will confirm whether or not the turnhead( ) function works. If it doesn't, you will need to change it. Once you have proved that part works, you can worry about the distance measurement logic.
michinyon: Do you have adequate power supply to the servo ?
Something you don't think about when programming is the ground part. I connected all the ground wires to one point and now it works. It is still not very smooth, but I can work on that in the code! ;)
