I'm not sure what I should try to do next in order to resolve the following problem. Suggestions will be greatly appreciated.
I have a device with three HC-SR04 Ultrasonic Sensor Distance Modules connected to an Arduino Uno. The echo and trigger are connected to pins 1 to 6. The distance reported is zero for all detectors.
However, when I connect trig/echo from each detector to pins 12 and 13, the detectors provide a reasonable distance. I tested all the detectors and their associated wires. So, the detectors and wires are not defective.
To make sure the pins are working, I connected each to a LED/resistor and did a digitalWrite to HIGH and LOW. The LEDs blinked for pins 1 to 6. I did not test digitalRead.
The documentation for pulseIn does not describe any pin limitations.
There are sample sketchbooks that use pins other than 12 and 13, so I am assuming that pins 1-6 should work with the detectors. Is this assumption incorrect?
Suggestions for next steps will be greatly appreciated.
