HC-SR04 doesn't work when it's connected to Arduino Motor Shield R3
Hi, I'm a new user of arduino and this is my first project.
I'm trying to build a robot that avoid obstacles.
I have both the Arduino Motor Shield R3 and the HC-SR04 sensor and they work fine by them selves but when I connect the sensor to the shield it doesn't work probably, it detect up to 6-7cm only or some times more than 1000cm when the sensor itself can't detect more than 500cm (look at the attachment).
this is the code that I use to test it out:
#include "ArduinoMotorShieldR3.h"
#include <NewPing.h>
#define TRIGGER_PIN  7  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     4  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
ArduinoMotorShieldR3 md;
  md.init();
  delay(15);
  unsigned int dist= sonar.ping_cm();
  if(dist != NO_ECHO && dist < 30) {
    md.setSpeeds(200,0);
  } else  {
    md.setSpeeds(200,200);
also the motors doesn't work the same, one is faster than the other.
and when I connect the battery to the arduino board(4 1.5v AA), it doesn't work the same as when it's connected by USB.
Deleted...
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Your code will help a lot.
Sorry you have.... :o
Have you checked if the two pins used by the SR04 is not used by the motor shield?
Yes that is normal.
TomGeorge:
The pins used by the shield are 3, 8, 9, 11, 12 and 13. And this is the library I'm using for the shield GitHub - gallingern/arduino-motor-shield-r3: Arduino library for the Arduino Motor Shield R3 .
And the circuit is in the attachment.
Ohh dear.. the OPs image... not circuit diagram.
Tom... :slight_smile:
TomGeorge:
I'm sorry I don't know what that is :cry: :cry: :'(.
Can you give me an example of what you mean? I'm sorry for being annoying :sweat_smile:
Reading a schematic
http://blog.makezine.com/archive/2011/01/reading-circuit-diagrams.html
Colin's Lab video on reading a schematic
Is the x-tal on your sr04 a 4MHz?
I have many of those.. working on USB-power (4.95v), but NOT when I user external power and the bord got 5V
All my sr04 with an 8 MHz xtal works independent of power source
