HC-SR04, GPS, and SD card reader with Arduino MEGA
Finally finished school project to make a device to take distance measurement, take gps fix, then upload this data onto an SD card! Doesn’t look pretty but it works!
#include <NewPing.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <SPI.h>
SoftwareSerial mySerial(11,10);
Adafruit_GPS GPS(&mySerial);
char c;
String NMEA1;
String NMEA2;
#define TRIGGER_PIN 31
#define ECHO_PIN 33
#define MAX_DISTANCE 200
#define pingSpeed 2000
#define chipSelect 53
unsigned long pingTimer1, pingTimer2, pingTimer3, pingTimer4;
NewPing sonar(31,33,65);
File myFile;
  pingTimer1 = millis() + pingSpeed;
  pingTimer2 = pingTimer1 + (pingSpeed/2);
  pingTimer3= pingTimer2 + pingSpeed;
  pingTimer4= pingTimer3 + pingSpeed;
  GPS.begin(9600);
  GPS.sendCommand("$PGCMD,33,0*6D");
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  if(!SD.begin(53)) {
    Serial.println(F("not beginning"));
    return;
  Serial.println(F("its working"));
  if(! SD.remove("ultrad.txt")){
    Serial.println(F("ultra not working"));
  if(!SD.remove("gps.txt")){
  Serial.println(F("gps not working"));
  return;
  Ping();
  GPSdata();
  SDCARD2();
void Ping(){
 Serial.print(F("Ping: "));
 Serial.print(sonar.ping_cm());
 Serial.println(F("cm"));
  if((sonar.ping_cm()<= 65) && (sonar.ping_cm()>0)){
  myFile = SD.open("ultrad.txt", FILE_WRITE);
  myFile.print(sonar.ping_cm());
  myFile.print(",");
  myFile.print("cm");
  myFile.print(",");
  myFile.print(GPS.hour, DEC);myFile.print(':');
  myFile.print(GPS.minute, DEC);
  myFile.print(",");
  myFile.print(GPS.month, DEC);
  myFile.print("/");
  myFile.print(GPS.day, DEC);
  myFile.print("/");
  myFile.println(GPS.year, DEC);
  myFile.close();
void GPSdata() {
  clearGPS();
  while(!GPS.newNMEAreceived()) { //loop until you have a good NMEA sentence
    c=GPS.read();
  GPS.parse(GPS.lastNMEA()); //parse that last good NMEA sentence
  NMEA1=GPS.lastNMEA();
    c=GPS.read();
  NMEA2=GPS.lastNMEA();
  Serial.print(GPS.latitude);
  Serial.print(F(","));
  Serial.println(GPS.longitude);
  Serial.print(GPS.hour, DEC);Serial.print(':');
  Serial.println(GPS.minute, DEC);
void clearGPS() {
    c=GPS.read();
    c=GPS.read();
    c=GPS.read();
void SDCARD2(){
  myFile = SD.open("gps.txt", FILE_WRITE);
  myFile.print(GPS.latitude);
  myFile.print(",");
  myFile.print(GPS.longitude);
  myFile.print(",");
  myFile.print(",");
  myFile.print("/");
  myFile.print("/");
  myFile.close();
