HC-SR04 Hack
Hey all, I would like to measure a distance with HC-SR04 the way sensor works is the echo length corresponds to distance so it give something like this on the scope :
what my prof wants to see is a trigger signal and a received signal then the distance between them, like below :
__
Trigger: | |______
__
Received: ______| |
But this isnt how HC-SR04 is designed, the sensor unfortunately doesnt have any schematics or a proper datasheet. I was able to find the trigger signal, but I cant find the received signal, there are around 24 pins behind I tried all of them one by one with the scope but couldnt succeed. I would be glad if you can give a hint...
Summary : where shall I put the scope probe to catch the received pulse... to display on scope?
http://elecfreaks.com/store/download/HC-SR04.pdf
Yes like I said, it doesnt have a proper datasheet, I added elecfreaks to my skype but they didnt give me any schematics or further help.
Did you try looking at the output of the pin labeled "ECHO"?
It seemed very clear from the data sheet that this is exactly what you wanted.
The pin ECHO gives the first output which I drew, this is how HC-SR04 works usually but I would like to find the pin which gives the "recieved" pulse and has a small peak like I drew on the second drawing(Trigger & Received)
The module can't send back the echo pulse until it has actually received an echo. Furthermore, there probably isn't much of a delay (certainly less than 1 millisecond and most likely a constant) between the onset of the return pulse and the beginning of the echo pulse.
I will bet that with some trials, you could figure out the delay fairly precisely. Set the module to be several different known distances from a wall and investigate the timing.
jremington:
you're clearly not understanding the question. the echo pin returns a pulse proportional in length to the delay between the TX and the RX. student7's question is how to get the raw sonic data coming back, which would be (approx) a fixed width pulse but with a delay (before the pulse starts) corresponding to the distance.
student7:
did you find the answer? (i have the same question...)
That's not how I read it.
The solution I see simply turns the falling edge of "echo" into a rising edge.
If you want the raw return, just scope-up the rear of the Rx transducer; it isn't rocket surgery.
There used to be full schematics available for the very similar Devantech devices.
you could connect it to the Arduino pin 2 , use attachinterrupt and when the signal changes generate an appropriate signal on 2 output pins.
