HC-SR04 making a alarm
Hello i wanna make an alarm with my hcsr-04.
My problem is i dont know how i can programm it.
Here my sketch:
#include <NewPing.h>
#define TRIG_PIN 5
#define ECHO_PIN 11
#define MAX_DIST 400
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DIST); // NewPing initialisieren
delay(50);
unsigned int distanceCM = sonar.ping_cm();
Serial.print(distanceCM);
Serial.println(“cm”);
Now i just can read how many cm my object is away.
But i want that if the number is under 5cm an led turns on.
can someone help me?
if (distanceCM < 5)
  //code here to turn LED on
  //code here to turn LED off
Read this tutorial to learn “Conditional Statements“ (If … then … else…).
#define TRIG_PIN 5
#define ECHO_PIN 11
#define BUILTIN_LED 2
  pinMode(ECHO_PIN, INPUT);
  pinMode(TRIG_PIN, OUTPUT);
  digitalWrite(BUILTIN_LED, HIGH);
  pinMode(BUILTIN_LED, OUTPUT);
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(5);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO_PIN, HIGH);
  cm = (duration/2) / 29.1;
  Serial.print(cm);
  Serial.println(" cm");
 if (cm <= 5)
    digitalWrite(BUILTIN_LED, LOW);
    Serial.println("LED ON");
    Serial.println("LED OFF");
Hope this could help…
