HC-SR04 ( Ultrasonic Distance Sensor)
I m using HC-SR04 ( Ultrasonic sensor) with arduino. It's Ranging Distance is 2cm - 400 cm and measuring Angle is 30 degree. Is there any low cost Ultrasonic distance sensor available whose measuring Angle is more than 30 degree?
Put the rangefinder on a servo. Then you can scan up to about 180 degrees. Or use more than one rangefinder.
