HC-SR04 Ultrasonic range finder is not working
Hi, I am using a HC-SR04 Ultrasonic range finder to measure distance using ultrasound. However, the sensor is not measuring any distance and the reading on the serial monitor is “Out of range”. Also, the red LED is always on.
Here is the link from where I used the code and circuit:
And here is the code:
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  if (distance < 4) {  // This is where the LED On/Off happens
    digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
  digitalWrite(led2,LOW);
  else {
    digitalWrite(led,LOW);
    digitalWrite(led2,HIGH);
  if (distance >= 200 || distance <= 0){
    Serial.println("Out of range");
  else {
    Serial.print(distance);
    Serial.println(" cm");
Please help.
Look at THIS PAGE and try the code there; we know it works...
