HC-SR04 Ultrasonic Sensor Help
Greetings everyone,
I am a novice with arduino and I am trying to build a project using an Arduino UNO, 3 x HC-SR04 ultrasonic sensors and 3 x small vibrating motors. My plan is to make each motor vibrate only when at specific distance range in cm. The sensors will be positioned Front, Left and Right. The hardware section of the project i am good with it is just programming is my weakness. I would very much appreciate someone's help to get started on the code. Thank you in anticipation for your kind assistance.
Regards
MasterKhem
Have you tried any of the example code for the sensors and motors?
What problems did you have?
