HC-SR04 Ultrasonic sensor throwing out wonky values with DC motor
Hey, so I'm using an ultrasonic sensor to control the speed of my DC motors. Pretty straightforward stuff, except that when I run the code on my Arduino, the ultrasonic sensor throws up garbage values or keeps oscillating between values when the DC motor starts up. I am assuming this is because of the noise emitted by the DC motor. My 3V DC motor also emits a high pitched frequency noise when running below a signal of 125. I am using a 3V DC motor, HC-SR04 ultrasonic sensor, Arduino UNO and I am powering all of it with my Arduino board. How do I get rid of this issue? Code is below
include <NewPing.h>
NewPing sonar(9, 8, 500);
int motor = 3;
void setup() { // put your setup code here, to run once:
pinMode(motor, OUTPUT);
while(!Serial);
void loop() { // put your main code here, to run repeatedly:
int time_ms = sonar.ping_median(5);
int distance = sonar.convert_cm(time_ms);
Serial.println("The distance is ");
Serial.println(distance);
delay(1500);
