HC-SR501 Adjustment?
Can i adjust waiting time to zero when the sensor turns off?
i can adjust sensitivity and output timing but i want that sensor react emedietly when light is turns off,
usually sensor wait for 2-3 seconds...
Hi all,
I have the same problem,
is there any solution for this ?
Some of websites about product info say "you can adjust this" but there is no info about it
PIR sensors are designed to react slow, to stop false triggering.
If you want to undo that, then you have to change the parts on the PIR board.
Or use a different sensor, like a grid-eye.
Leo..
Wawa:
Leo..
Thanks for the answer
But i found 2 different products ;
  1. https://www.mpja.com/download/31227sc.pdf
  2. HC-SR501 PIR motion sensor « osoyoo.com (Features 7)
Delay and blockade times are different in these products,
so their board are different,
so my question is, have can i find second one ? :slight_smile:
Uh, also find this product:
https://www.rapidonline.com/pdf/74-1108_V2.pdf
