I am attempting to make a sound installation using HC-SRO4 sensors to map the noise too, I was originally planning to adapt the AUDUINO synthesiser and have built it using potentiometers and wanted switch them out for the sensors, due to my basic knowledge of Arduino it was too difficult for me, but if anyone could help me work it out it would be greatly appreciated!!!
I am using an Arduino UNO R3
But because of this I decided to try my own, I have been able to map the distances provided by the sensors to some scales, but I don't know how to get the Arduino to make a noise aha whether it be a tone or a play function im unsure how to make it work, ill leave the code here too.
// Include NewPing Library
#include "NewPing.h"
#include <avr/io.h>
#include <avr/interrupt.h>
// Define Constants
#define TRIGGER_PIN_1 10
#define ECHO_PIN_1 10
#define TRIGGER_PIN_2 5
#define ECHO_PIN_2 5
#define MAX_DISTANCE 4000
#define PWM_PIN 3
NewPing sonar1(TRIGGER_PIN_1, ECHO_PIN_1, MAX_DISTANCE);
NewPing sonar2(TRIGGER_PIN_2, ECHO_PIN_2, MAX_DISTANCE);
// Define Variables
float distance1; // Stores calculated distance in cm for First Sensor
float distance2; // Stores calculated distance in cm for Second Sensor
float tone1;
float tone2;
int output;
uint16_t minorpentatonicTable[55] = {
0,17,20,23,26,31,34,41,46,51,61,69,82,92,103,122,137,163,183,206,244,274,326,366,
411,489,549,652,732,822,978,1097,1305,1465,1644,1955,2195,2610,2930,3288,
3910,4389,5220,5859,6577,7821,8779,10440,11718,13153,15642,17557,20879,23436,26306
uint16_t mapminorPentatonic(uint16_t input) {
uint8_t value = (1023-input) / (1024/53);
return (minorpentatonicTable[value]);
uint16_t minordiatonicTable[76] = {
0,17,19,20,23,26,27,31,34,38,41,46,51,54,61,69,77,82,92,103,109,122,137,154,163,183,206,218,244,274,308,326,366,
411,435,489,549,616,652,732,822,871,978,1097,1232,1305,1465,1644,1742,1955,2195,2463,2610,2930,3288,
3484,3910,4389,4927,5220,5859,6577,6968,7821,8779,9854,10440,11718,13153,13935,15642,17557,19708,20879,23436,26306
uint16_t mapminorDiatonic(uint16_t input) {
return (minordiatonicTable[value]);
Serial.begin (9600);
pinMode(PWM_PIN, OUTPUT);
void play ( int output ) {
digitalWrite(PWM_PIN, HIGH);
delayMicroseconds(output);
digitalWrite(PWM_PIN, LOW);
distance1 = sonar1.ping_cm();
// Add a delay between sensor readings
delay(10);
// Measure duration for first sensor
distance2 = sonar2.ping_cm();
// Send results to Serial Monitor
Serial.print("Distance 1: ");
if (distance1 >= 4000 || distance1 <= 2) {
Serial.print("Out of range");
else {
Serial.print(distance1);
Serial.print(" cm ");
Serial.print("Distance 2: ");
if (distance2 >= 4000 || distance2 <= 2) {
else {
Serial.print(distance2);
Serial.print(" cm");
Serial.println(" ");
tone1 = mapminorDiatonic( distance1 );
tone2 = mapminorPentatonic( distance2);
Thanks Guys, Much appreciated!!!
