IgnatzG
December 15, 2015, 9:29pm
1
I want to use a HC05 for communication with my arduino using Softwareserial and to IO-Pins.
To save power i want to disable the HC05 if i don't need it. I added a switch to the VCC pin of the HC06.
But every time i turn the power on my arduino is reset and starts over again but i want it to keep running.
Can someone help ?
IgnatzG:
Really?
If you refrain from turning the power off, Arduino will keep running. I submit that the HC-05 is entirely blameless.
IgnatzG
December 26, 2015, 3:12pm
3
Yes but i want to turn the bluetoth modul off. I can't see why the rx and tx pins used by the softserial lib shoul cause a reset when the power is turned on and off on the bluetoth modul .....
Voltage dip?
Perhaps you could be a bit more forthcoming with code, wiring, and power supply.
