hc05 bluetooth module disconnecting from device when sending data, plz help
hi
im trying to make a bluetooth car with arduino uno
everything is working good except… the bluetooth disconnects from my phone everytime i send a command
the bluetooth is wired like this:
→ state === x
Level:3.3V ← RXD === (RX ← 0)
→ TXD === (TX ← 1)
← GND === (GND)
Power.3.6v–6v ← VCC === (5V)
← EN === x
i tried 4 “1,5 AA” batteries, it didnt work even the 9v didnt work
when i tried 2 “1,5 AA” batteries the bluetooth didnt turn on
i dont think there is anything wrong with the wires cuz i checked everything for like a thousand time
i started doing the car 3 weeks ago and im still trying to make it work
the arduino code:
//Arduino Bluetooth Controlled Car//
// Before uploading the code you have to install the necessary library//
//AFMotor Library Library Install | Adafruit Motor Shield | Adafruit Learning System //
#include <AFMotor.h>
//initial motors pin
//AF_DCMotor motor1(1, MOTOR12_1KHZ);
//AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
char command;
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
Serial.println(“Start”);
void loop(){
if(Serial.available() > 0){
** command = Serial.read();
** //Change pin mode only if new command is different from previous. **
** //Serial.println(command);**
** switch(command){**
** case ‘F’: **
** forward();**
** break;**
** case ‘B’: **
** back();**
** break;**
** case ‘L’: **
** left();**
** break;**
** case ‘R’:**
** right();**
** break;**
void forward()
//motor1.setSpeed(255); //Define maximum velocity
//motor1.run(FORWARD); //rotate the motor clockwise
//motor2.setSpeed(255); //Define maximum velocity
// motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(255);//Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(255);//Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
void back()
// motor1.run(BACKWARD); //rotate the motor anti-clockwise
//motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.setSpeed(255); //Define maximum velocity
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.setSpeed(255); //Define maximum velocity
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
// motor1.setSpeed(255); //Define maximum velocity
//motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor4.run(BACKWARD); //rotate the motor clockwise
void right()
// motor1.run(FORWARD); //rotate the motor clockwise
// motor2.setSpeed(255); //Define maximum velocity
//motor2.run(FORWARD); //rotate the motor clockwise
motor4.run(FORWARD); //rotate the motor anti-clockwise
void Stop()
//motor1.setSpeed(0); //Define minimum velocity
//motor1.run(RELEASE); //stop the motor when release the button
//motor2.setSpeed(0); //Define minimum velocity
//motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
thats all plz help its been long time and im still trying
ty for reading
What Arduino do you have?
Your description of the wiring is not understandable.
It should be connect as follows to a 5V Arduino (Uno, Nano, Mega):
BT enable not connected
BT Vcc to 5V
BT ground to ground
BT TX to Arduino RX
BT RX to Arduino TX via a voltage divider (drops Arduino 5V to 3.3V for the Bluetooth module)
BT state not connected
Here is a page with very good information on using the HC05 modules.
I would use a software serial port for the Bluetooth module so that the hardware serial port is free for program upload, monitoring and debugging.
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask an effective question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
the same thing happens with me
it happens because while receiving data from arduino the power supply fluctuate and therefore your arduino bt disconnects
so give an external supply of 5v to bluetooth module
and you will be thanking me.
