HC05 doesnt send data from phone to pc
I witnessed a problem where hc05 sent data from pc to phone but it works only in one way. So when i try to type from my phone ,pc cant get that data
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 2); // RX=3, TX=2
  Serial.begin(9600);   // PC communication
  mySerial.begin(9600); // HC-05 communication
  Serial.println("Ready! Send data from phone...");
  // Check if HC-05 is sending data (Phone → Arduino)
  if (mySerial.available()) {
    String data = mySerial.readStringUntil('\n');
    Serial.print("Received: ");
    Serial.println(data); // Print to Serial Monitor
  // Check if Serial Monitor is sending data (PC → Phone)
  if (Serial.available()) {
    mySerial.write(Serial.read()); // Relay to HC-05
that is the code . i checked connection of wires and it is ok ,also i made a loopback test so both tx and rx is working
pls help meUse code tags to format code for the forum
Please, wrap your code like this...
Can you also post the "loopback" test you did?
You are going to need a picture of a hand drawn wiring diagram, what you describe seems to be missing at least one part. Also Use the Tools Auto Format command before posting your code in code tags.
i just connected the tx to rx on HC05 and write a message in serial monitor from phone .Eventually that message was receive back
i checked wires and find out that there was a problem. Thanks you all for help and now everything works
