HC05 FCC certification.
I am trying to develop a arduino based bluetooth robot for commercial purpose. Can I use HC05 module for bluetooth communication in my product and Is it FCC certified? or How else should I check HC05's compliance with FCC rules?
Awaiting your reply
Thanks in Advance.
the HC-05 is almost definitely FCC certified. I think that to be sold in the US, radio things have to be compliant. So you should be fine. BTW, try the HM-11 BLE module. I think it is used the same way, but it has better range and uses less power.
harishryder: Hi,
Awaiting your reply
Thanks in Advance.
If it does not come identified as being FCC certified, its probably not. Identification is either a label or instruction manual with the manufacturer name and FCC file number etc.
Items manufactured in China are often not certified. If the item is shipped direct from a warehouse in China - I suggest further investigation is warranted so you don't run foul of the law and face a big fine.
If delivery is ex-NA (US/CA) and not compliant, the importer could be in hot water.
