Hello everyone, i am using a hc05 module powered by an asm1117 5v regulator with an input of 8v and the module gets hot atfer a couple of minutes, with time it get more and more even the regulator is heating
Dispose of the regulator and the HC-05 safely, and start over.
Next time, triple check, then wait for a day and check twice again, that pinouts are correctly identified and wired before powering up the assembly.
Post a wiring diagram.....
Sounds like something is broken or you have it wired wrong.
12v2A smps goes into a buck converter lm2596 hvs that ouptus 8v where i have 2 decoupling caps, one ceramic and one foil, 8v goes into the asm1117 5v regulator that have a 220uF cap betwen Vin and gnd and 100uf one at the hc05 input in paraled with a ceramic 104 cap. Tx of hc module goes to arduino rx and arduin tx to a level converter then in rx. My wonder is why the hc module gets hot and also the regulator
Read reply #4 again. Word sallad often leads to misunderstandings, and tiresome to use.
