This come mostly off the web, but I had to correct the Receiver side , this will allow you to transfer any number of numeric variables,.
//Transmitter
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial HC12(10, 11);//tx,rx
type or paste code here
int variable1;//variables that will get sent
int variable2;
int variable3;
int variable4;
int variable5;
HC12.begin(9600);//Sets the hc 12 communication to 9600 baud, which is their factory default
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
variable1 = 10; //assigns the variables that will be sent
variable2 = 50;
variable3 = 80;
variable4 = analogRead(A3);
variable5 = 215;
//Uncomment the following lines if you want the remote to also send the analog input
//data to the serial monitor, to check if the data is being read properly
//If you do, It will look the same as it should on the other end's serial monitor
//Serial.print(variable1);
//Serial.print(",");
//Serial.print(variable2);
//Serial.print(variable3);
//Serial.println(variable4);
//Serial.print(variable5);
//Serial.println("");
HC12.print(variable1);//sends the variables
HC12.print(",");
HC12.print(variable2);
HC12.print(",");
HC12.print(variable3);
HC12.print(",");
HC12.print(variable4);
HC12.print(",");
HC12.print(variable5);
HC12.println("");
delay(100);
//Receiver
#include <Wire.h>
int variable1=0;
int variable2=0;
int variable3=0;
int variable4=0;
int variable5;
String input;
int d1; //setup to reference delimiter locations so its easier to follow
int d2;
int d3;
int d4;
const char delimiter = ',';
HC12.begin(9600);
if(HC12.available())
input = HC12.readStringUntil('\n');
if (input.length() > 0)
Serial.println(input);
d1 = input.indexOf(delimiter);
//Serial.println(d1);
variable1 = input.substring(0, d1).toInt();
d2 = input.indexOf(delimiter, d1+1);
//Serial.println(d2);
variable2 = input.substring(d1+1, d2).toInt();
d3 = input.indexOf(delimiter,d2+1);
//Serial.println(d3);
variable3 = input.substring(d2+1, d3).toInt();
d4 = input.indexOf(delimiter, d3+1);
//Serial.println(d4);
variable4 = input.substring(d3+1, d4).toInt();
variable5 = input.substring(d4+1).toInt();
Serial.println(variable1);
Serial.println(variable2);
Serial.println(variable3);
Serial.println(variable5);
delay(10);
Results
10,50,80,239,215
10
50
80
239
215
